headlight issues
Old Jun 15, 2007 | 02:23 AM
dombombBMX's Avatar
Default headlight issues
hey all... so heres the deal.. i pull into get something to eat... get in my car and drive off... i realize my headlights are not on.. they wont turn on. switch it all the way up and no go. blinkers dont work, or the wipers.. now the brights do work but i have to pull it towards me and hold it on.. they wont go the other way and stay on.. the side corners and the back lights are still working...
what the heck is going on here... ???
i just got home and didnt really check anything like fuses or whatnot.. any help would be nice... thanks guys
btw its a 1998 a4 avant quattro 2.8 wagon
Old Jun 15, 2007 | 02:28 AM
Jeff's Avatar
Zombie Defense Force
Default RE: headlight issues
blinker fluid is low.
i think your switch relay is messed up. its a common problem and i dont remember how exacly to fix it. but if you search it will come up. you have to take it apart and spray it with electrical cleaner and that should fix it. it think
Old Jun 15, 2007 | 07:30 AM
A4 Effort's Avatar
I had the same problem about 2 years ago. It may be as simple as cleaning the switch, or it may not.
In the end, i had to replace myentire headlight switch.
Old Jun 15, 2007 | 10:30 AM
CRAZYHAWK's Avatar
Try spraying the switch with RadioShack Contact Cleaner.
Old Jun 15, 2007 | 04:11 PM
patchelect's Avatar
Headlight issue but not the same. Figured I'd just hang it on this thread.
Car '04 Quattro 3.0 Cabriolet. Owned for a few months. Leaving headlights in the auto position will occasionally result in a buzzer/tone/beep that only goes away when the headlight switch is turned to the off position. The car is garaged so the lights will go on when the car is started. Haven't noticed it when we get home and they turn off, only during daylight hours. The sound goes away as does the problem, whenever the switch is turned to off and it also doesn't seem to have any consistency. It may be weeks or it may be only days.
Anyone have any experience with this type of problem?
Also have experienced the climate control being on a different setting at startup than when the car was shut off- ie: set at 65 when turned off and set at 68 when restarted or even set "Off" without ever changing the controls.
Old Jun 15, 2007 | 08:07 PM
dombombBMX's Avatar
so i bought a new ignition switch and put it in.. whhhaalaa everything was working again!!! yay!!! looking at the old one you could see one of the pins was melted around it and whatnot.. once i seen that i knew that was the problem... i guess the only downside to it all was the switch was 83 bucks from the stealership... i didnt feel like waitin for an order online.
the install is super easy... if you can loosen about 10 bolts you can do this. so if you have the problem with your headlights, turnsignals and windsheild wipers not working mainly all at once, i could bet that this is your problem - ignition switch
thanks peeps for your input. now i cruise much happier
Jrmiller
Feb 25, 2013 03:03 PM
TheBeardedFury
Jun 1, 2012 11:42 PM
snibborfm
Nov 9, 2008 09:40 AM
MBear
Nov 19, 2007 08:11 PM
TBarCYa
Feb 26, 2007 10:06 PM
