Tire Pressure Monitoring
Old Mar 3, 2008 | 01:45 PM
rreishman's Avatar
Default Tire Pressure Monitoring
My tire pressure monitoring system has failed. At first it could be reset and then there was a malfunction notice and now new pressures cannot be set.
Has anyone else experienced problems in this area?
This is a 2004 A8L
Bob Reishman
Old Mar 15, 2008 | 07:17 PM
CosminTX's Avatar
Default RE: Tire Pressure Monitoring
ok... this info is from a6 bentley service manual , is how to store the current tire pressure in the monitoring system:
- switch ignition on and acces the start menu from instrument cluster driver info display.
-move selection arrow to set by rotatingturn /pushknob
-press turn/ push ****. setting menu apers
-move selection arrow to tire pressureby rotating the ****
-press turn/ push ****. submenu tire pressure appears
-move selection arrow to store pressure!
-press **** and turn. a check mark appears. system responds with the current tire pressure will be saved
-move selection arrow to back
- press **** to leave tire pressure menu.
this is what`s in the book , i did`n try it yet , but i will to see if i have the monitor system on my car, hope this helps.
lysal
Feb 22, 2008 07:03 PM
helenbol
Nov 4, 2007 07:50 AM
ultrasport
Dec 29, 2006 02:07 AM
paulsha911
Nov 8, 2006 12:32 PM
toysnob
Aug 25, 2005 11:07 AM
