Exterior Talk about your rims, body kits, and other exterior mods here.
BBS RXII 8Jx18H2 is causing a squeaky sound
Old May 10, 2006 | 12:56 AM
Ray95762's Avatar
Default BBS RXII 8Jx18H2 is causing a squeaky sound
From my brakes. At first I didn't think the wheels would cause the brakes to squeak but the Brake guys couldn't find anything wrong. Has anyone ever experienced squeaky brakes after putting on new wheels?
Old Jun 12, 2006 | 01:10 AM
apfelbaum's Avatar
Default RE: BBS RXII 8Jx18H2 is causing a squeaky sound
I'm going to assume that you checked for rubbing and hitting and all that good stuff. If it isn't the telltale howl of the wear indicator on the pads touching down, then I would think you might need some anti-squeel compound on the back of the pads. The higher load of the larger rims and footprint is probably causing the pads to work harder and therefore moving around a bit in the caliper, resulting in squeeling. HTH
Erick Figueroa
Dec 14, 2012 01:59 PM
careercadaver
Apr 5, 2012 10:32 AM
greenturbo
Aug 6, 2009 05:08 PM
SnowSurfns
Jul 23, 2007 02:32 AM
98A4TQ
Mar 6, 2007 02:55 AM
