Exterior Talk about your rims, body kits, and other exterior mods here.
Removing scratches
Old Sep 23, 2009 | 02:34 PM
mattolson's Avatar
Default Removing scratches
I have a bunch of scratches on my bumper and driver's side back panel, not sure what they are from, but I am starting to upgrade my car and it just looks ugly now. Its weird cause you can see the primer through the scratches but its still smooth to the touch. Here are some pics that will hopefully show you what I mean. I basically just want to know what the best way to get rid of these damn things is.
http://img197.imageshack.us/i/scratchside.jpg/
Old Sep 24, 2009 | 06:26 PM
pa4ul's Avatar
someone keyed my car and i got the meguires nxt text wax and it got the scrathes out. OTher then that might want to see how much it would cost to touch up.
Old Sep 24, 2009 | 08:23 PM
Midniteoyl's Avatar
That doesnt look like primer, it looks like the clearcoat. You should be able to use some compound and buff it out.
Old Oct 23, 2009 | 06:21 PM
D.SoyNC's Avatar
joe why dont you just use some non metallic primer? i used it on my dash and its been painted for 2 years now with no flaking what so ever
Old Jan 3, 2010 | 11:02 AM
Alpinestar03's Avatar
Most of those scratches will come out. Color sand (wet sand) lightly with 2000 grit wet or dry paper.
Then use a 1500 grit compound on a NON ORBITAL buffer with a cotton pad.
Change to a foam finishing buff pad and 2000 or 2500 grit finishing paste.
I work at a body shop and do alot of minor sctratch repair. Just remember to stay away from edges with the paper and buffer. You'll burn ritght through the paint. I'd also reccomend using 3M compounds, paper and buff pads.
Good luck!
eric
NJ@BoroKidA6
Feb 15, 2007 02:56 PM
TheJazz7
Apr 6, 2006 08:12 PM
slimmj0k3r
Sep 10, 2005 09:00 PM
Nasty
Mar 29, 2005 06:08 PM
Nasty
Mar 27, 2005 02:30 AM
