Exterior Talk about your rims, body kits, and other exterior mods here.
wheel fitment
Old Oct 22, 2005 | 01:12 AM
fayaz925's Avatar
Default wheel fitment
ok guys i jus bought rims for my 2001 audi a4, when the rims fit on, they move around until i can line up the lug nuts to put them in, will that be a problem? its for audi a4 with 5x112pattern. plz help asap, thanks guys
Old Oct 25, 2005 | 12:33 PM
4dot's Avatar
Default RE: wheel fitment
no it shouldn't be a problem. if i understand your question correctly, you're just asking if the 5x112s will fit the a4 when you line them up to put them on. as long as your offset isn't something outragous you're good.
Old Oct 26, 2005 | 10:17 PM
BadLuckAudi's Avatar
No it’s not a problem; the lug nuts will center the wheel so it’s in the right spot and keep it from moving. If I understand you correctly you should be fine.
Old Nov 7, 2005 | 05:23 PM
A4PM's Avatar
Will the 05 wheels fit on an 03?
Old Nov 24, 2005 | 07:22 PM
dankhound's Avatar
Does the inside back of the wheel fit snuggly onto the hub? It should. It sounds like you may be missing some hub inserts for the wheels.
ADubyaD
Dec 18, 2008 03:43 PM
audiRSallroad
Jul 6, 2008 01:49 AM
turbokingz
Mar 9, 2008 10:39 PM
cenci
Oct 1, 2006 06:41 PM
QtroSpeed
May 16, 2005 04:25 AM
