Wheel Fitment
Old Dec 17, 2008 | 09:17 PM
ADubyaD's Avatar
SoCal Crew Member
Default Wheel Fitment
I have a 2ks4 that i want to slap some 5x100 rims from the s line TT on there, If I used 12mm spacers I could run them with my stock bolts no problem right?
Old Dec 17, 2008 | 10:46 PM
Blue_S4's Avatar
thats not what a spacer does...a spacer means its puts the wheel 12mm further from the hub. you need hub/wheel adapters to make that work...but i really would not recommend that. the sizing is that size because of reason, you go too small, you loose some strength in there...dont forget, your car makes much more power than a TT.
Old Dec 18, 2008 | 10:31 AM
drobrt's Avatar
Yep, what he said ^^. I just put some 2004 S4 rims on my S4 and the wheels were scrappin the caliper. So I bought some 10mm spacers on em it just spaced the wheel farther out so it no longer rubs. Plus it gives the wider more aggresive look.
Old Dec 18, 2008 | 03:43 PM
JohnnyS4's Avatar
I couldn t find a wheel adapter to fit .unless you like your wheels sticking out past your fender. i was given a set of porche 5 star twists reps off of a vw bug . was going to be my winter wheels. I still need to get rid of them.
allradkamerad
Oct 12, 2011 06:50 AM
audiRSallroad
Jul 6, 2008 01:49 AM
turbokingz
Mar 9, 2008 10:39 PM
cenci
Oct 1, 2006 06:41 PM
QtroSpeed
May 16, 2005 04:25 AM
