[A4] differential and transmission
Old Apr 17, 2008 | 11:51 PM
zakario's Avatar
Default [A4] differential and transmission
do you need a key to drain and fill the transmission and the differential or just the transmission??
Old Apr 18, 2008 | 11:17 PM
nemohm's Avatar
Default RE: [A4] differential and transmission
Most of the real cars have 3 differentials.
What model is yours?
Are you refferinig to car key ot to a wrench?
What is the problem, please provide specifics.
Old Apr 18, 2008 | 11:23 PM
SAudi's Avatar
not sure on the automatic (id have that done at the dealership or independent shop since its a PITA) but teh 5 speed has a special tamper proof bit that you can pick up at ECStuning and the fill plug is a 17mm hex socket. ther rear diff uses a 10mm hex socket for the fill and drain plug
heres the diy for the tranny
https://www.audiforums.com/m_156758/tm.htm
and the rear diff
http://www.audiworld.com/tech/misc33.shtml
hotgrass
May 11, 2008 02:26 PM
speedys4
Mar 13, 2008 10:58 PM
hxgaser
Feb 20, 2008 11:14 AM
mustang196718
May 1, 2007 02:48 PM
psaario
Sep 21, 2006 04:26 PM
