01 1.8t ce light code p00011 HELp
Old 03-09-2012, 09:51 PM
ko4b5's Avatar
Default 01 1.8t ce light code p00011 HELp
im new here and dont know alot about audi i have only had mine about a week and i bought the car with a bad turbo so i decided to go with a ko4 i just installed it and did a oil change on my car i added a over size oil filter as i was advised to do from a friend that owns a audi like mine but that aside i took the car for a test run and didnt turn it but 5k rpm no ce light then i ran it to red line and the ce light came on i scanned it and it gave the code p00011 i have never seen this code before and really dont have a idea of what caused it i googled it and looked on other forums with no luck can some one please help me diagnose the problem
Old 03-10-2012, 07:33 AM
M5S5's Avatar
Tech Certified
The fault code is probably a p0011 Camshaft A retard set point not reached.
It is possible there could be an oil psi problem.
Reset fault , drive normally & see what happens. If it comes back on it would be a good idea to check oil pressure.
Old 03-10-2012, 11:54 AM
ko4b5's Avatar
I did find a oil leak also my dipstick funnel is broke and it's spewing oil out I can't even check my oil level but it looks to b low couldn't that b the cause from what little I could find I the code low oil could cause this wright??
alinux
09-28-2008 02:34 AM
ThePizza
04-23-2008 04:58 PM
TheBat
02-12-2008 04:58 PM
SnowSurfns
07-09-2007 11:27 PM
Fieldy
12-30-2004 09:23 PM
Quick Reply: 01 1.8t ce light code p00011 HELp
