06 audi a6 bogging/ruff running
Go to Autozone, get a free code scan, and post the codes here. Then we can help answer the questions. There are lots of things that could cause that to happen and if the CEL is on, that's your first indicator of a problem. The car will tell you a lot about what's going on through the codes.
Good. The scan tools they use will pull the correct codes, but they don't always define them correctly. When you have the codes, post them here and we can define them for you and send you on the right path to a solution.
