1999 A6 Warning lights and no tach
Old Nov 16, 2011 | 05:19 PM
metalmelitia's Avatar
Default 1999 A6 Warning lights and no tach
So i recently purchased a 99' Audi A6 non-turbo, non-quattro. 2.8L V6. while driving it today all of a sudden
-ABS light solid
-brake light blinking
-low oil light indicator blinking
-tach drops to zero
all of these things occur at once. they then will go away for a while, then come back. any experience with this or a possible fix?
Old Nov 16, 2011 | 05:32 PM
02A6Beau's Avatar
hrmmmm.
the C5 A6 is/was not available in a 2.7 liter non-turbo engine. I suspect you probably have the 2.8
regardless, your first step is to get a scan. preferably a vag-com VCDS scan but in your situation any OBDII scanner will do for a start. then we will see where we go from there.
based on your intial symptoms, your ABS module is going (blinking brake light+ABS light and you should be getting a BEEP! BEEP! BEEP!)
low oil light and tach are probably unrelated unless they are related
Old Nov 16, 2011 | 05:41 PM
you are correct about it being 2.8L mistype on my part. I have to believe they are all related since all of the lights come on and the tach stops working simultaneously and they all turn off together as well and the tach resumes normal function. the local audi dealership was fairly useless.
Old Apr 23, 2015 | 10:43 AM
david671023's Avatar
have you sloved the issue? What you do?,Ihave the exactly same issue.
Old Apr 24, 2015 | 08:03 AM
Yes, it has been solved. Inside the ABS module there there are 2 very small aluminum pins which supply the power. They eventually break loose from the circuitboard. You have to resodder them to the board. Do not attempt this if you are not qualified.
andy.p1980
Jan 10, 2016 02:38 PM
andy.p1980
Sep 30, 2013 04:47 PM
franko
Dec 22, 2011 11:28 PM
boffin58
Dec 21, 2005 03:29 PM
toolrocks
Sep 7, 2005 05:21 AM
