2.7t exhaust and turbo CFM flow rates
Old Mar 4, 2008 | 06:35 PM
SharpHID's Avatar
Default 2.7t exhaust and turbo CFM flow rates
Does anyone know what the CFM capacity of the stock K03 turbo is? Also how efficient is the existing exhaust on a 2.7t motor (dual exhaust) and how much does it flow? Any info on the exhaust manifolds would be much appreciated also.
Thanks all!
John
Old Mar 4, 2008 | 07:01 PM
tHe kNiGHt FaLL's Avatar
Default RE: 2.7t exhaust and turbo CFM flow rates
turbo aren't rated using CFM... you use engine CFM to find which turbo is best for the engine using a pressure ratio formula.
Old Mar 5, 2008 | 01:33 AM
SharpHID's Avatar
ORIGINAL: tHe kNiGHt FaLL
Are you sure? I can get a complete list of the CFM capacity of all the Mitsubishi turbos used in the Eclipse, Saabs, and Volvos regardless of what engine is connected. Turbos will only flow so much air before they become inefficient. Too little air and they won't work either.
Old Mar 24, 2008 | 11:52 PM
SharpHID's Avatar
Anyone know what the 2.7T engine flows for CFM?
bryso21
Aug 25, 2011 12:55 PM
14psi
May 8, 2008 12:31 AM
zelpdsm
Mar 6, 2008 09:33 PM
True_Pinoy
Dec 2, 2006 01:06 AM
orionuv
Jan 6, 2006 12:40 PM
