2000 A4 center console
Old May 18, 2007 | 12:28 AM
Gunter_'s Avatar
Default 2000 A4 center console
ok,2000 a4,turbo 4 cylinder,auto.
i am replacing the dash and airbags,and cant get the last of the fasteners for the center console.2 10mm's above the radio, 2 screws (one by each seat either side of shifter)one under the dash on each side.
what i am missing is: the order of dis assembly
does the radio come out first?i have the console by the parking brake lever re moved,and cant get the center console(front half against the dash) out.it has to come out as it covers other fasteners holding the dash pad on.
thanks for the help
Old May 18, 2007 | 10:44 AM
techbod's Avatar
Default RE: 2000 A4 center console
Storage compartments/covers[/align]Removing and installing components of rear section of centre console[/align]
Cassette box
‒Remove rear section of centre console => Page
‒Press fastener on cassette box and remove cassette box. [/ul]
Mat lining
Mat for telephone in armrest
Mat for telephone in centre console
Mat for cassette box [/ul]
Mat lining
Cover for diagnostic connector
â—†Pull off cover of diagnostic connector to rear. [/ul]
To be cut out for cassette box
Drinks holder
Storage compartment
‒Remove bolts -11- (2x).
‒Pull drinks holder downwards and to rear with retainer tabs -12- out of holders -13-. [/ul][/ul]
Bolts (2x)
‒Tightening torque 1.5 Nm [/ul]
Retainer
Retainers
Rear centre console [/ul]
[IMG]local://upfiles/12092/A50B33FE0399430DA5923D1915A3CE42.jpg[/IMG]
Old May 18, 2007 | 10:55 AM
techbod's Avatar
just in case its the other type set up[/align][/align]Storage compartments/covers[/align]Removing and installing front section of centre console[/align]
Bolt (4x)
‒Tightening torque 5 Nm [/ul]
Front section of centre console [/ul]
â—†Removing
‒Remove trim for centre section of dash panel
‒Unscrew heater control from centre section of instrument panel
‒Unclip cover -3-.
‒Unscrew nut -4-.
‒Unscrew bolts -1- (4x).
‒Disengage centre console from position -A- and pull out to rear. [/ul][/ul]
â—†Installing
‒On installation centre console must be inserted into fastener -5-. [/ul][/ul]
Cover
Nut
‒Tightening torque 3.5 Nm [/ul]
Fastener [/ul]
Fig.:3Removing centre section of dash panel
‒→ Unscrew bolts -2- (4x). Tightening torque 5 Nm.
‒On vehicles with air conditioning unscrew bolts -4- (2x). Tightening torque 3.5 Nm.
‒On vehicles with heater unscrew bolts -6- (4x). Tightening torque 5 Nm. [/ul]
‒Disengage centre section of dash panel -1- at top from the two guides, pull it forward slightly and detach wiring.
‒Tray -3- is only unclipped. [/ul]
Fig.:4Removing cover for dash panel centre section
‒Removing radio.
‒On vehicles with heater: Pull off heater control ***** -3- (3x) and unscrew bolts -4- (2x). Tightening torque 3.5 Nm.
‒Unclip trim -1-. [/ul]
[IMG]local://upfiles/12092/CAD3CC1757DB4BCC8A342D5575453880.jpg[/IMG]
[IMG]local://upfiles/12092/9C48640BE1C541DC99B581B16BC5CDC3.jpg[/IMG]
[IMG]local://upfiles/12092/53070DF91CA8445CA19D7A882970B428.jpg[/IMG]
Old Jun 9, 2007 | 04:41 AM
csuflyboy's Avatar
I have the same center console as the last picture - but I'm having difficulties removing the climate controls. It appears they're installed with 1-way clips. I think the climate controls need to be removed first in order to get to the last two 8mm bolts (behind the CCs) holding the center console to the dash...is this correct? Can you post more detail about figure "A70-0027" please?
Thanks!
Matt
Old Jun 9, 2007 | 05:38 AM
csuflyboy's Avatar
Nevermind..I just needed to use a bigger hammer. Actually, I pried it out by sliding a screwdriver between the metal bracket and the back of the plastic housing of the climate controls.
idfnl
Jan 4, 2008 11:09 PM
Bogie
Nov 28, 2007 12:22 AM
lionelcastr0
Sep 21, 2007 02:57 PM
seattlea6
Aug 6, 2007 02:41 PM
mrdb85
Oct 17, 2006 01:22 PM
