2000 Audi A6 P1568
Old Dec 3, 2011 | 09:28 PM
12merc's Avatar
Default 2000 Audi A6 P1568
Hello All Im new to the forums and heres my problem. 2000 Audi A6 quattro 2.8 120,000 miles. Had a code for bank one and bank two secondary air injection I removed the intake and the combination valves cleaned reassembled that code went away but now i have the P1568 code on EPC lights on and the engine is running terribly on two cylinders (1,6) i replaced plugs wires and coils any idea on where i should look next? not sure what the code is for i had to use global obdII and the description was bad thank you for any info on this problem
Old Dec 5, 2011 | 03:13 PM
12merc's Avatar
Forgot to mention that's the only code no misfire codes could the throttle actuator having a mechanical fault cause ur to run on two cylinders ?
Old Dec 9, 2011 | 06:00 PM
12merc's Avatar
Any ideas?
Old Dec 14, 2011 | 11:55 PM
Cutebaby1's Avatar
I have too the same problem...Needed to resolve. The A6's styling is unmistakably Audi, with a swept greenhouse and muscular fenders. However, the A6 isn't a stunner like the A4.
Old Apr 29, 2012 | 08:39 PM
duck4u1987's Avatar
Ok so i had the same prob! Take the throttle body off. pop open the TPS ( the black plastic cap on the throttle body ) USE ELETRONIC CLEANER and q-tips clean it real good then put it back together hook it up and that should fix the prob...... atleast it did for me..
gilliethakidd
Jun 18, 2012 07:11 AM
duck4u1987
Apr 29, 2012 08:33 PM
nukauto
Feb 2, 2008 11:02 PM
