2002 A4 Wont Start
Old Nov 22, 2015 | 12:17 PM
mz83's Avatar
Default 2002 A4 Wont Start
I have an 2002 A4 1.8t Quattro. It was starting to have some hard to start issues and then one day just wouldnt start. I used a normal OBD2 scanner and have not was not getting any codes. While watching in in real time mode noticed that the throttle body was giving off readings. I borrowed a friends vagcom to do a throttle body adaptation. The vagcom gave me throttle body error that i couldnt clear and it wouldnt let me do the throttle body adaptation. I went to the junk yard and pulled a throttle body but it still would not allow me to run the adaptation. I get code 17987 - Throttle Actuator (J338) Adaptation Not Started P1579.
Would this cause the car not to start? I know coming from the junkyard the throttle body I got could be bad but what else should I be looking for here?
Thanks
Matt
Old Nov 24, 2015 | 10:58 AM
dave944's Avatar
The first thing you need to do for weird electrical issues is check the wiring harness grounds. There are a couple for the engine. Simply loosening and retightening them can fix the issues.
Old Nov 28, 2015 | 05:01 PM
mz83's Avatar
Thanks Dave. I just ran some new ones and the car started. I still have to get a hold of Vagcom to do the adaptation but she has started after sitting a few weeks.
Old Nov 28, 2015 | 06:37 PM
dave944's Avatar
Excellent. Hope you get her going for good now.
Dylan Cure
Sep 4, 2012 04:21 AM
zslatcher
Oct 24, 2011 06:13 AM
Billydakid
Oct 29, 2010 02:40 AM
mark944turbo
Oct 10, 2005 05:51 PM
