2009 Audi A3 1.9 TDI wont start after crash
Old Feb 20, 2014 | 12:52 AM
avish.mpls@gmail.com's Avatar
Default 2009 Audi A3 1.9 TDI wont start after crash
Hi Please help my 2009 Audi A3 1.9Tdi won't start after crash, i get all the lights on the cluster and beeps but don't get any sound from the engine when i turn the key.
No sound from the solenoid, and no noise from the fuel pump.
Scan below!!!!!!!!!!
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WAUZZZ8PX9A059449 Mileage: 106140km/65952miles
01-Engine -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Sporadic communication error 1000
52-Door Elect, Pass. -- Status: Cannot be reached 1100
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AF HW: 1K0 907 379 AF
Component: MABS MK70M 0104
Revision: 00H32001
Coding: 0016641
Shop #: WSC 06314 000 00000
VCID: 76E9977C015519A80A7
6 Faults Found
57344 - Unknown Error Code
Unknown - 015 - - MIL ON
00283 - ABS Wheel Speed Sensor; Front Left (G47)
012 - Electrical Fault in Circuit - Intermittent
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
01314 - Engine Control Module
004 - No Signal/Communication
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH09 0100
Revision: 000031 Serial number: 8P0820043BG
Shop #: WSC 00000 000 00000
VCID: 72E1AB6C6D3D058826F
10 Faults Found
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 18
Reset counter: 99
Mileage: 106144 km
Time Indication: 0
Freeze Frame:
Temperature: -50.0°C
Voltage: 12.50 V
RPM: 12750 /min
Load: 0.0 %
Load: 0.0 %
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 59
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 5
Reset counter: 59
Mileage: 106144 km
Time Indication: 0
Date: 2012.06.23
Time: 00:00:01
Freeze Frame:
ON
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 59
Mileage: 106144 km
Time Indication: 0
Date: 2012.06.23
Time: 00:00:01
Freeze Frame:
ON
00532 - Supply Voltage B+
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 6
Reset counter: 99
Mileage: 106144 km
Time Indication: 0
Date: 2012.06.23
Time: 00:00:43
Freeze Frame:
Voltage: 8.60 V
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 59
Mileage: 106144 km
Time Indication: 0
Date: 2012.06.23
Time: 00:00:01
Freeze Frame:
ON
01332 - Door Control Module; Passenger Side (J387)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Date: 2012.06.23
Time: 00:00:01
Freeze Frame:
ON
01273 - Fresh Air Blower (V2)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 3
Reset counter: 99
Mileage: 106144 km
Time Indication: 0
Date: 2012.06.23
Time: 00:37:17
Freeze Frame:
Speed: 325.0 km/h
(no units): 137.0
(no units): 248.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 99
Mileage: 106144 km
Time Indication: 0
Date: 2012.06.23
Time: 00:00:09
Freeze Frame:
Speed: 325.0 km/h
(no units): 137.0
(no units): 248.0
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 59
Mileage: 106144 km
Time Indication: 0
Freeze Frame:
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000009017055
Coding: 08A82F81B0141380EF00001C0000000000094A056401040300 A800000000
Shop #: WSC 06314 000 08192
VCID: 489529843B21DF58A8B
Component: Fehler Lin-Slave 01
10 Faults Found
00987 - Lamp for Brake Light; Left (M9)
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 99
Mileage: 106144 km
Time Indication: 0
Date: 2012.06.23
Time: 00:00:00
Freeze Frame:
Raw, Form. N/A: 000 000 000
Raw, Form. N/A: 000 000 136
OFF
00988 - Lamp for Brake Light; Right (M10)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 99
Mileage: 106144 km
Time Indication: 0
Date: 2012.06.23
Time: 00:00:00
Freeze Frame:
ON
Voltage: 12.50 V
OFF
Code Not Found: TNF 128 135
Current: 2048 mA
OFF
OFF
01506 - Bulb for Rear Fog; Right (L47)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 106144 km
Time Indication: 0
Date: 2012.06.23
Time: 00:00:00
Freeze Frame:
ON
Voltage: 12.45 V
OFF
ON
OFF
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 59
Mileage: 106144 km
Time Indication: 0
Date: 2012.06.23
Time: 00:00:00
Freeze Frame:
ON
Voltage: 12.50 V
OFF
ON
OFF
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 59
Mileage: 106144 km
Time Indication: 0
Date: 2012.06.23
Time: 00:00:00
Freeze Frame:
ON
Voltage: 12.50 V
OFF
ON
OFF
OFF
OFF
00927 - Terminal 30 (Right)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 98
Mileage: 105433 km
Time Indication: 0
Date: 2012.06.19
Time: 17:15:00
Freeze Frame:
OFF
Voltage: 12.40 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 59
Mileage: 106144 km
Time Indication: 0
Date: 2012.06.23
Time: 00:00:00
Freeze Frame:
ON
Voltage: 12.45 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 99
Mileage: 106144 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.55 V
OFF
ON
OFF
OFF
OFF
02745 - Bulb for Daytime Running Light; Left
Freeze Frame:
Fault Status: 01111100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 59
Mileage: 106144 km
Time Indication: 0
Date: 2012.06.23
Time: 00:13:00
Freeze Frame:
ON
Voltage: 12.00 V
OFF
ON
OFF
OFF
OFF
02746 - Bulb for Daytime Running Light; Right
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 59
Mileage: 106144 km
Time Indication: 0
Date: 2012.06.23
Time: 00:13:00
Freeze Frame:
ON
Voltage: 12.00 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels: Redir Fail!
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142383038303031324A55305238503000
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 49932C80E82B2650B75
Crash sensor for side airbag; passenger side:
Serial number: 3582DRB400007FB4CACF
Crash sensor for side airbag; rear driver side:
Serial number: 35128RB400004633DBFU
Crash sensor for side airbag; rear passenger side:
Serial number: 35228RB4000045C13416
Crash sensor for front airbag; driver side:
Serial number: 35547RB40000473B575M
Crash sensor for front airbag; passenger side:
Serial number: 35647RB40000473BD52Q
14 Faults Found
9443093 - Driver's Side Airbag Crash Sensor
B1017 15 [137] - Open or Short to Plus
MIL ON - Confirmed - Tested Since Memory Clear
9437211 - Igniter for Driver's Airbag
B1000 1B [137] - Resistance Too High
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 106144 km
Date: 2012.06.23
Time: 00:00:03
9440027 - Driver's side; side-airbag igniter
B100B 1B [137] - Resistance Too High
9440026 - Driver's side; side-airbag igniter
B100B 1A [136] - Resistance Too Low
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
9437467 - Igniter 2 for Driver's Airbag
B1001 1B [137] - Resistance Too High
9437723 - Igniter for Passenger's Airbag
B1002 1B [137] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 106144 km
Date: 2012.06.23
Time: 00:00:03
9438747 - Igniter for Seat Belt Tensioner; Driver's Side
B1006 1B [000] - Resistance Too High
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 106144 km
Date: 2012.06.23
Time: 00:00:03
000000 - SAE - Reserved by Document ISO 15031-6
P0000 00 [000] - 2005
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0000042
VCID: 418334A0181BEE106F5
No fault code found.
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 931 S HW: 8P0 920 931 S
Component: KOMBIINSTR. VDO H18 0830
Revision: D0H18006 Serial number: 2249H0060
Coding: 0004828
Shop #: WSC 03163 996 13762
VCID: 438F3EA80207FC007D9
3 Faults Found
00779 - Outside Air Temp Sensor (G17)
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 59
Mileage: 106144 km
Time Indication: 0
Freeze Frame:
Raw, Form. N/A: 000 000 011
00562 - Sensor for Oil Level/Temperature (G266)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 99
Mileage: 106144 km
Time Indication: 0
Date: 2012.06.23
Time: 00:01:04
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 99
Mileage: 106144 km
Time Indication: 0
Date: 2012.06.23
Time: 00:02:56
Address 19: CAN Gateway Labels: Redir Fail!
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K08A06130D
Coding: E9807F061002022103
VCID: 356B50705CD352B0C3D
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 25: Immobilizer
Cannot be reached
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1880200002186D0985054C9FC677
Component: Sounder No Answer
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Component: IRUE No Answer
13 Faults Found
01135 - Interior Monitoring Sensors
01134 - Alarm Horn (H12)
00926 - Terminal 30
00950 - Central Locking Motor - tailgate (V53); UNLOCK
007 - Short to Ground - Intermittent
01038 - Central Locking Thermal Protection
000 - - - Intermittent
00332 - Control Circuit for Tank Flap
01403 - Glass-Break Sensors; Rear
011 - Open Circuit
00955 - Key 1
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
01565 - Luggage Compartment Light (W3)
Robi959
B7 Models
Jan 11, 2020 07:28 PM
itsjoeeffen
Mar 2, 2015 08:36 PM
benghazi08
Oct 14, 2014 02:41 PM
mark944turbo
Oct 10, 2005 05:51 PM
