2010 1.8 TFSI Transmission and Differential Fluid Chage
Old Jan 14, 2017 | 12:35 PM
moonlightblue's Avatar
Default 2010 1.8 TFSI Transmission and Differential Fluid Chage
Hello all,
I bought a 2010 1.8TFSI Audi with manual transmission.
To have a smoother drive I decided to change the diff and trans oil which I do at every car without any issues.
The sticker under the bonnet says that TAF X oil for the manual transmission.
I have 3 questions:
1- I had a research on google and found out that TAF X stands for Castrol 75W90 GL4 oil is that true?
2- I could not find any info in regards to the Differential Oil type of this car? Should I use 75W90 GL5 or 80W90 GL5 or something different for the differential?
3- How much oil do I need?
Look forward to hearing from you all.
Cheers
David
Old Jan 23, 2017 | 02:02 AM
Problem solved. FYI Went with fully syn Castrol V 75W80 (4.2lt) and so far so good.
audi1812
Jul 12, 2013 11:42 PM
yellow_submarine
Feb 3, 2011 04:25 AM
konabiker47
Jan 20, 2009 09:28 PM
FlyPenFly
Nov 1, 2007 06:41 PM
nyaudia498
Mar 3, 2007 01:04 PM
