30V Quattro Transmission Problems
I am having shifting problems with my 1998 model Auto Tiptronic 30V 2.8 (80,000km). I went to see an independant repairer and was told that it is becoming a general problem. Has does enyone heard of this problem. I believe it is n E19 box.
if the tip doesn't change gears - it's probably the magnetic strip under the plastic cover of the the gear selector. the magnetic strip triggers the tiptronic gear selection (upshift / downshift). if it is damaged, misaligned somehow, tip won't function. transmission is otherwise ok.
if so, just need to replace it. i think ~ $200 to have audi mechanic fix.
