95 audi a6 window problems
Old Jun 7, 2011 | 02:21 PM
jackieviolet's Avatar
Default 95 audi a6 window problems
I recently purchased a 95 audi a6. The other day I rolled the windows down and now they will not roll back up. None of the windows will do anything. I've been researching on the internet to try to find out what the problem is and have found a few things but not sure what is right.
I can not find out if there is a window relay, I do not see one anywhere. I tested the fuses and they are fine.
I have heard it could be the ignition. And believe that is probably the issue seeings how when I turn the key to start the car you have to manually turn the key back to the proper position because the spring in the ignition is broke and doesn't push it back on its own.
Also, I don't know if I am supposed to buy just the ignition switch or a whole new lock, key and cylinder
Please Help!!!!!!!!!!!!!!
Old Jun 7, 2011 | 11:05 PM
jesswestcoast's Avatar
It might the driver side wiring harness. Check in the door jamb remove the rubber and check the wiring.
h4x0r
Dec 31, 2011 12:20 PM
goodh20
Sep 5, 2009 04:48 PM
coreym
May 23, 2008 08:29 PM
CamGriffin
Jul 4, 2006 04:42 PM
auDi1.8TQ
May 15, 2005 05:04 AM
