A3 turning but not starting?
Old Jul 31, 2018 | 07:16 PM
vanya's Avatar
Default A3 turning but not starting?
2003 A3 2.0 FSI, 114k miles, AXW engine code
First post to the forum, my A3 turns over but won't start. The 2 fault codes that come up are P0341 and P0420. The first one is related to the camshaft sensor, which I have now replaced however that seems to have made no difference. The check engine light is not on. From what I've read it seems that either fault code can be causing the car not to turn on so I want to narrow the problem down before spending money. The fuel pump works, air filter isn't clogged and I can't find any blown fuses.
Please can anyone help??
Old Aug 24, 2018 | 06:37 PM
JETSPEED333's Avatar
SoCal Crew Member
check the wiring to the cam/crank sensors. check the pins for corrosion/bent
check the fuses very carefully..... I had a fuse test good with a DVM but then when load was applied would not start.... had a no spark condition... finally pulled the fuses to find one was damaged.
good luck
check timing belt and compression too
mb1
Aug 28, 2013 01:29 AM
phil martin
Feb 29, 2008 12:19 PM
ballin
Nov 11, 2006 04:03 AM
speedypat
Jan 28, 2006 10:24 PM
ellenbec
Nov 23, 2004 10:58 PM
