A3 VIBRATION/RUMBLING NOISE!!
Old Jun 21, 2006 | 03:30 PM
CHRIS L's Avatar
Default A3 VIBRATION/RUMBLING NOISE!!
My A3 makes a weird noise/vibration when turning right, whatever speed im going. I have taken it to my local garage and they said it was a front ball joint gone but after now having this replaced the noise is still there! It only happens when turning right and seems to be coming from the back!!
Does anyone have any ideas??
Old Jun 25, 2006 | 02:00 PM
dankhound's Avatar
Default RE: A3 VIBRATION/RUMBLING NOISE!!
Sounds like a left rear wheel bearing going out.
Old Aug 23, 2006 | 04:08 PM
flandavi1980's Avatar
I have the same problem, however it appears to go away when clutched in. Did you ever find a solution to your problem?
Old Aug 23, 2006 | 04:12 PM
techbod's Avatar
when clutch is in?? sounds like a thrust bearing, to check if a wheel bearing is going the noise will get louder at speed if the noise only happens when turning I would think C/V joint
indo247
Aug 24, 2012 02:32 AM
Shwabmyknob
Dec 14, 2008 07:32 PM
ssandjjj
Mar 24, 2008 06:01 PM
SFRS6
Apr 22, 2006 08:19 PM
AVA4AV
Jan 23, 2006 02:27 PM
