A4 2.8 1997 timing belt change
Old Aug 16, 2009 | 10:30 AM
hellperados's Avatar
Default A4 2.8 1997 timing belt change
Hi guys
I'm planning to change the thermostat and the timing belt on my 97 A4 2.8 in the next few weeks. the car have 183 000 km. Is the anything else I should also change while doing that? Should I also change the timing cover gasket? Which is the best shop manual I should use? I'm trying to get all the parts and info prior to start the job.
Thanks
Remi
Old Sep 7, 2009 | 10:39 PM
flyboy's Avatar
Change the water pump while your in there. Its not that expensive and is very easy to get to once you have her opened up. As far as a shop manual, I couldn't tell you. I can walk you through it tho.
steve1997AudiA4
Aug 11, 2015 02:20 AM
fourringking
Jan 11, 2013 12:44 AM
G3ML1NGZ
Nov 22, 2012 09:33 PM
vsolrac
Nov 24, 2006 09:52 PM
juice88
Aug 5, 2005 11:42 AM
