A4 2.8 BRAKE PROBLEMS! EXPERT HELP NEEDED
Old Nov 29, 2006 | 04:42 AM
kadajx666's Avatar
Default A4 2.8 BRAKE PROBLEMS! EXPERT HELP NEEDED
2 out of 5 times when i step on the brake pedal slowly approaching a stop sign my car would rumble, it happens when i initiate the braking and i can feel it rumbling through the brake pedal. does anyone know what needs to be fixed???[&o]
thanks
Old Nov 29, 2006 | 03:24 PM
puremskirby's Avatar
Default RE: A4 2.8 BRAKE PROBLEMS! EXPERT HELP NEEDED
Clean your ABS sensor at all four corners or get new units. This requires some work, removing tires to gain access to the sensor and or removal. I would recommend Electrical cleaner from your local hardware store or parts shop but brake cleaner will work fine.
Old Nov 29, 2006 | 05:40 PM
luvin_the_rings's Avatar
yup, same thing happend to me, just clean those sensors, and if that doesnt work, get some new units...
if the abs light comes on you can scan the code and find out what wheel is doing it, that might save you some time/money
mondo
Dec 9, 2012 12:26 AM
JeniSkye
Mar 17, 2012 01:30 PM
marcb0127t
Jun 9, 2010 07:54 PM
mjwhiat
Feb 9, 2010 09:14 PM
G
Oct 11, 2006 10:49 PM
