A4 B7 running very rough, misfire, oil on spark plugs
Old Mar 10, 2016 | 10:20 PM
Matthew Heydenburg's Avatar
It's still running rough. At least when in idle. I didn't drive it today. I'm planning on getting some ethanol free 93 tomorrow and adding the injector cleaning solution. Running in idle it still sounds like I have a misfire. The exhaust is pretty choppy and it's still pretty rough. Definitely improved though.
Old Mar 11, 2016 | 11:57 AM
dave944's Avatar
Sounds like a plan.
Old Mar 13, 2016 | 09:40 PM
Ran STP for about 10 minutes which completely took away misfire on cylinder 4. I still have misfire on 3 though. Does this sound like I need a new injector?
Old Mar 13, 2016 | 09:49 PM
dave944's Avatar
I'd run it a little longer. It may take a little more STP running though it to get it cleaned out. Take it for a short drive.
Old Mar 14, 2016 | 09:51 AM
I drove it for maybe 2 miles. It was in a hilly and winding area so I never got it over 40mph. Definitely improved since the last time I drove it (beginning of this post) as I could actually get up to 40, but still very rough. I didn't see any improvement after this drive in it's idle compared to yesterday. The good news is I'm still only getting a code for cylinder 3 and nothing else. I'm concerned running it much longer might damage my catalytic converter and I really don't want to have to replace that. Does it sound like the injector should be my next plan of attack?
Old Mar 14, 2016 | 11:28 AM
dave944's Avatar
Pull the spark plug on that cylinder and see what it looks like. You might even try a new one in that hole first. If that doesn't fix it a idle, I would go ahead with an injector.
Old Mar 14, 2016 | 12:46 PM
The sparks are practically new. So I'm thinking fuel pump. Would the repair kit fix this or will I need a completely new pump?
Old Mar 14, 2016 | 02:28 PM
  #18
dave944's Avatar
I don't think it's a the fuel pump. You'd be getting misfires on all cylinders since a fuel pressure drop would affect all the injectors.
Old Mar 14, 2016 | 03:00 PM
  #19
Sorry, I meant injector. There is also an injector repair kit. I'm ordering both and if it just needs the kit I'll return the injector.
Old Mar 14, 2016 | 08:18 PM
  #20
dave944's Avatar
I see your evil plan... LOL
The repair kit is just the o-rings, a hat for the tip and possibly a filter insert on the supply side. You could try that first since it is a much cheaper.
