A4 starting trouble
Old May 22, 2007 | 07:31 PM
darkstaraudi's Avatar
Default A4 starting trouble
I have An A4 1999 V6 V30 Quattro and its have trouble starting. It only happens every now and then but it seems to not want to turn over. I can hold the key for a minute or two but it just makes the beginning nose like its about too but wont and when it finally dose a black smoke comes out the exhaust that sells like gas and oil. Any suggestions ?????????????????
Old Jun 20, 2007 | 03:37 PM
a4_avant's Avatar
Default RE: A4 starting trouble
I got the same problem if you find out please let me know. Thanks!
Old Jun 20, 2007 | 03:43 PM
techbod's Avatar
check the battery out ( is the alternator charging it? or is the battery bad ) could also be bad ground wires
Old Jun 20, 2007 | 05:14 PM
CRAZYHAWK's Avatar
Check the ECU for codes and post them.
Old Jun 20, 2007 | 06:48 PM
rbrtech's Avatar
Check the crank sensor codes will tell you.
Old Jun 20, 2007 | 06:58 PM
rbrtech's Avatar
or engine speed sensor I meant
Old Jun 22, 2007 | 07:56 PM
steviejayvaughan's Avatar
sounds like an intermittant coolant temp sensor issue.
Old Jun 23, 2007 | 01:58 PM
auditech79's Avatar
ORIGINAL: steviejayvaughan
The engine would still crank fine with a faulty cts sensor, good guess though.
ferret
Nov 30, 2014 11:13 AM
DubSeelVR6
Sep 20, 2010 04:38 PM
munster79
May 18, 2008 06:23 PM
drtymune
Mar 7, 2008 08:30 AM
Delano
Mar 31, 2006 11:17 AM
