A6 with ABS sensor issue
Old Jul 18, 2008 | 04:20 PM
petedonlan80's Avatar
Default A6 with ABS sensor issue
I have a 2002 A6 with 112,000 miles on it. The ABS warning light comes on sporadically at any speed, along with a brief burst of the ABS system. The dealer says I need a new "yaw rate sensor" and the part is $800. I'd be OK with just driving it as is, but the ABS coming on at highway speeds cannot be good for the system.
What are my options? Thanks, Pete
Old Jul 19, 2008 | 01:39 AM
ImTheDevil's Avatar
Default RE: A6 with ABS sensor issue
Unless your car has some sort of yaw control system (which it might), it could be an ABS (aka wheel speed) sensor freaking out. Those are a lot less money (about $150 for the A4, likely comparable on the A6). Ask him for the OEM part number and I'm sure you can find it somewhere online for significantly less than his quoted price.
Old Jul 21, 2008 | 01:52 PM
Sethg10's Avatar
If it's giving you faults for a yaw sensor, then it doesn't have anything to do with the wheel speed sensors. Your yaw sensor is under the middle of the back seat (which just pulls out by the way). I have seen a vehicle that kept throwing a fault for that sensor even after it was replaced. The other options are wiring issues, or the abs control module. None of which are too cheap. If it was my car, I would leave it alone.
Old Aug 14, 2008 | 04:05 PM
zemon3's Avatar
Getting the same message. I googled and it looks like you may change the sensor and shortly after the light will come back on as Sethg10 Said. $800 is an expensive "my bad". Thanks Sethg10.
Old Aug 15, 2008 | 06:22 PM
CRAZYHAWK's Avatar
You'll need a VAG-COM. Read the 3rd computer codes.
Old Aug 15, 2008 | 10:18 PM
SAudi's Avatar
if you want a real quick fix and dont mind sacrificing the abs and EDL (locks the wheel in snow if they loose grip) just pull the abs fuse.
luckynow
Sep 17, 2010 08:43 AM
careercadaver
Aug 19, 2010 08:40 AM
soldierboy15
Apr 21, 2009 04:42 PM
LeftFrank
Sep 11, 2008 09:46 PM
modset
Jan 19, 2008 11:28 PM
