ANY IDEAS?
Old Apr 19, 2008 | 09:58 PM
zakario's Avatar
Default ANY IDEAS?
I checked out the rear wheel bearings and CV boot/shaft/ bearings on my audi A4 98' 1.8 (aeb) and they appear to be ok but there is still excess road noise. It sounds like a bearing problem of some sort but the wheel doesn't pull to either side so I don't think its a front wheel bearing....could it be a problem with one of the differentials? the sound oscillates somewhat at speed but doesn't change pitch
Old Apr 19, 2008 | 10:07 PM
tHe kNiGHt FaLL's Avatar
Default RE: ANY IDEAS?
a bad wheel bearing unless its binding won't cause it to pull when driving.
you wanna check your wheel bearings... jack up the wheel you suspect being bad and spin the wheel freely. put your hand on the knuckle where the upper control arms mount in and feel for a vibration...
Old Apr 19, 2008 | 10:12 PM
zakario's Avatar
is there anything else that could possibly be the reason?
B6A4Ohio
Feb 10, 2011 04:22 AM
B6A4Ohio
Nov 26, 2010 05:26 PM
Crekuc
Nov 3, 2008 09:59 PM
chefnic26
May 30, 2007 10:54 PM
shkenned
May 21, 2007 11:58 PM
