ATX valve timing fault
Hi, sorry if this is the wrong section.
I have a 2001 A4 Quattro witch broke a cambelt. Heads were repaired, running nicely except for uneven idle.
Valve timing is spot on as per ELSA. VCDS shows valve timing bank 2 out.
What I did find was that, in display group 90, display 3&4 wasn't the same ie display 3 shows +22kw and 4 shows -22kw with cam control activated.
PLease advice, scan included
VIN: WAUZZZ8DZ1A072327
Mileage: 242276 km
Address 01: Engine Labels: None
Control Module Part Number: 3B0 907 551 BF
Component and/or Version: 2.8L V6/5V G 0001
Software Coding: 04251
Work Shop Code: WSC 06435
Additional Info: WAUZZZ8DZ1A072327 AUZ7Z0Y1530734
VCID: 68D95B49084DD65E33D-5178
2 Faults Found:
17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28)
P1347 - 35-00 - Incor. Correl.
17930 - Camshaft Adjustment; Bank 2
P1522 - 35-10 - Malfunction - Intermittent
Thanks Johan
Mileage: 242276 km
2 Faults Found:
Thanks Johan
crisTSM
01-10-2013 09:02 AM
martini_zupa
01-25-2007 01:35 AM
