audi A4 2002 2.4 v6 B6 Transmission? problem
Old Mar 12, 2014 | 08:22 AM
CliffCork's Avatar
Default audi A4 2002 2.4 v6 B6 Transmission? problem
I am not really sure if its a tranmission problem or what it is.
Im new to this forum, and hoping I could get some advice on what to do or where to start looking. Here is my problem I am havin with my Audi 2002 A4 2.4 v6 B6. with 65000kms on the clock and I am experiencing the following. When the car is cold (first run of the day, or after a few hours of being parked), I do not have this issue as well as when the revs are below 1200 or above 1900. It feels like the car is unsure of when to change, and the revs blip up by 200rpm, but does change gears. This only happens at normal running temp and between 1200 and 1900 rpm. Also it feels like the car jumps/shudders during when it changes but this doesnt happen every time. I have put the car on diagnostics, and no codes whatsoever! I have
taken it to various mechanics around my country, and all are dumbfounded! Any suggestions would be greatly appeciated. We have changed the ATF oil etc.
Note that it DOES change gears, and when it is in that range of RPM it has this problem with any gear. When it is above 1900rpm it does NOT have this problem in any gear.
Old Mar 14, 2014 | 05:27 AM
Audi0's Avatar
I have been keeping my eye on this thread as I have the exact same problem. I have a 2001 B6 1.8T multitronic with 65000 miles on the clock.
I'm not sure why the OP hasn't received a response yet, but can anyone confirm that cleaning the throttle body, as explained in the 1.8T common problems thread, would cure it?
Some advice would be really appreciated.
As this problem seems to be on the B6 model, could admin possibly move this to the A4 B6 forum, where it might get a bit more attention please?
Thanks in advance.
Old Mar 14, 2014 | 08:59 AM
CliffCork's Avatar
Thanks in advance.
Ye man, lets hope we can have some repsonses and idea's. Where did you read that cleaning the throttle body would cure it? Can you post links?
Old Mar 14, 2014 | 10:05 AM
Audi0's Avatar
Hi CliffCork,
I found this Common troubleshooting guide on the A4 forum https://www.audiforums.com/forum/aud...g-guide-36092/ and just had a hunch that it was the throttle rather than the transmission.
In truth I have absolutely no idea and was just clutching at straws. I was hoping to prompt someone that does have an idea to give an answer here on what might be wrong.
In the meantime, if I do find out, I will be sure to come back and let you know what I have found out.
Old Mar 17, 2014 | 04:00 AM
CliffCork's Avatar
Hi CliffCork,
Thanks for the links man, I and a mechanic friend have also come up with a possible solution to it being the solenoids in the gear box? Any thoughts on that?
Old May 20, 2014 | 08:41 AM
CliffCork's Avatar
Hi CliffCork,
Hey man,
Have you had any success with your issues? I have not had any progress, and my car is the same, not worse not better. Really have no idea now?
Old Jun 5, 2014 | 10:55 AM
Audi0's Avatar
Originally Posted by CliffCork
Hey man,
Hi CliffCork,
I have my Audi booked in for a service on the 13th of this month and have mentioned the problem to them.
I will let you know the outcome.
Old Jun 6, 2014 | 08:26 AM
CliffCork's Avatar
Hi CliffCork,
Thank you very much Audi0, I really appreciate that!
Old Jun 16, 2014 | 03:18 AM
CliffCork's Avatar
Hi CliffCork,
Hi Audi0,
Any news from your service on friday?
NYP
Mar 26, 2012 11:23 AM
yrndtn
Nov 20, 2011 01:34 PM
balla915
Sep 27, 2009 08:24 PM
archie20
Jan 22, 2009 05:16 PM
mikeherman
Aug 3, 2007 09:25 AM
