Audi A4 B7 2007 electrical problems
Hi Guys, i bought this Audi A4 B7 2007 2.0 Tdi as a non runner. The previous owner told me that he left the passenger window open(right hand drive) and it rained that night. The following morning he saw a lot of water at the foot well. Tried to start the car but nothing. He had a mechanic to check the car and he found that the central convenience module was fried. It short circuited as the water penetrated it.
Long story short i replaced that module and the car still did not start. So i did a scan and found the following :
Monday,22,June,2015,16:26:19:05981
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
Ross-Tech: Home
VIN: WAUZZZ8E17A084848 License Plate: AUDI
Mileage: 164980km-102513mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E17A084848 Mileage: 164980km-102513miles
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BN
Component: A4 Klimaautomat 2833
Coding: 00000
Shop #: WSC 00000
VCID: 6ED576AA2A8058518C3-5102
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 01001
Shop #: WSC 06325
VCID: 3D7781E63766F3C9459-4B00
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 02041
Shop #: WSC 06325
VCID: 418FFD164B9E9729211-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 901 D HW: 8E0 920 901 D
Component: KOMBI+WFS 4 H14 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0006111
Shop #: WSC 01642 996 08954
VCID: 26454E8A92F05011343-5102
1 Fault Found:
01312 - Powertrain Data Bus
014 - Defective
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006111
VCID: 26454E8A92F05011343-5120
1 Fault Found:
014 - Defective
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
VCID: 6BD37FBE1992AD79ABD-5120
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4035
Coding: 00128
Shop #: WSC 06325
VCID: 79FF55F663CE0FE9291-4AE6
Subsystem 1 - Part No: 8E2959802F
Component: Tőrsteuer.FS BRM 0606
Subsystem 2 - Part No: 8E2959801F
Component: Tőrsteuer.BF BRM 0606
Subsystem 3 - Part No: 8E0959801E
Component: Tőrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tőrsteuer.HR BRM 0606
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 AA
Component: concert II GRO 0004
Coding: 01005
Shop #: WSC 06325
VCID: 66C50E8A02709011F43-4AE6
End-------------------------(Elapsed Time: 13:57)--------------------------
So as far as i could determine its a faulty cluster caused by the shortage in the circuit. And if i understand correctly the immobilizer is integrated in the cluster.
Any help and advice would be gladly appreciated.
Ross-Tech: Home
67 69 75 76 77
Coding: 00000
Shop #: WSC 00000
Coding: 01001
Shop #: WSC 06325
Coding: 02041
Shop #: WSC 06325
Coding: 0006111
1 Fault Found:
014 - Defective
Coding: 0006111
1 Fault Found:
014 - Defective
Coding: 00001
Shop #: WSC 00000
Coding: 00128
Shop #: WSC 06325
Coding: 01005
Shop #: WSC 06325
Question is, can i get another cluster from a donor car? I have heard that you cannot use a cluster from a donor car because it is coded for that specific car.
What would be the next steps ?
Hi guys, i am still struggling with the same problem. I lost hope for a while but decided to give it a go again.
So i went to a scrapyard and bought a lock set which includes the cluster,ecu,ignition+key and door lock from the same model car.
So i installed and tested it but i still get the same problem, "powertrain data bus defective ???
So what does this mean? Does it mean that i have a problem with my wiring or maybe with some of the other modules ???
My conclusion is one of the above but i dont know.
Anyway here is the scan results, hope someone can point me in the right direction. Thanks in advance.
Friday,23,December,2016,16:17:59:05981
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 15.7.4.1
Data version: 20160216
Ross-Tech: Home
VIN: WAUZZZ8E08A063068 License Plate: VNG 01
Mileage: 305720km-189965mi Repair Order:
67 69 75 76 77
VIN: WAUZZZ8E08A063068 Mileage: 305720km-189965miles
Coding: 00000
Shop #: WSC 00000
VCID: 6ED576AA2A80584E9C-5102
Coding: 01001
Shop #: WSC 06325
VCID: 3D7781E63766F3D655-4ACE
Coding: 02041
Shop #: WSC 06325
VCID: 418FFD164B9E973631-4AE6
Part No SW: 8E0 920 901 H HW: 8E0 920 901 H
Component: KOMBI+WFS 4 H14 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0006118
Shop #: WSC 73249 020 01196
VCID: 2A5DBABA86E8746E00-5102
1 Fault Found:
014 - Defective
Coding: 0006118
VCID: 2A5DBABA86E8746E00-5120
1 Fault Found:
014 - Defective
Coding: 00001
Shop #: WSC 00000
VCID: 6BD37FBE1992AD66BB-513C
Coding: 00128
Shop #: WSC 06325
VCID: 79FF55F663CE0FF639-4AE6
Coding: 01005
Shop #: WSC 06325
VCID: 66C50E8A0270900EE4-4AE6
End-------------------------(Elapsed Time: 11:20)--------------------------
Ross-Tech: Home
67 69 75 76 77
Coding: 00000
Shop #: WSC 00000
Coding: 01001
Shop #: WSC 06325
Coding: 02041
Shop #: WSC 06325
Coding: 0006118
1 Fault Found:
014 - Defective
Coding: 0006118
1 Fault Found:
014 - Defective
Coding: 00001
Shop #: WSC 00000
Coding: 00128
Shop #: WSC 06325
Coding: 01005
Shop #: WSC 06325
