audi a6 transmission problem
Old May 20, 2017 | 04:17 PM
addi55's Avatar
Default audi a6 transmission problem
i have a audi 2000 a6 1.8t station wich i bought with a broken engine.
ADR motor
some number on transmission 4D0 407 722E
i have recently bought a replacement engine from a 2001 a6 1.8t
AWT motor
some number on transmission : 4D0 407 722
my problem is that the transmission from the replacement engine is bigger than my original one and has an electronic caple at the back of it.
im not sure if what the difference is between those two and i cant find information on it anywhere.
some one here know anything of this ?
Old May 21, 2017 | 11:38 AM
dave944's Avatar
Some number on the transmission?
You really need to find another ADR engine since the ECU will be coded to run an ARD, not the AWT engine you got. Coupled with the fact that it's apparently physically different, you're pretty much going to have to return the AWT engine.
Gone are the old days of engines and transmissions being compatible with each other even within the same year model. Throw in the computer controlled aspect of it, and there's another level of incompatibility on top of the physical.
Old May 21, 2017 | 02:13 PM
addi55's Avatar
Hi there dave944.
Thank you for replying to my thread.
so there is no way that i could apply this engine/transmission to my audi.
i have the computer that came with the engine
Old May 23, 2017 | 08:48 PM
dave944's Avatar
If the transmission in the car and the engine you have will not bolt up, no...
A4tun81
Feb 16, 2010 05:45 PM
pattrick02
Jun 24, 2009 06:39 PM
mdeerfield
Dec 18, 2005 10:14 PM
99AudiA4q
Dec 12, 2004 12:31 AM
