Audi S3 1.8 T (2000) Fans Not Kicking In, Help Appreciated!
Old Dec 11, 2014 | 03:58 PM
redbul's Avatar
Default Audi S3 1.8 T (2000) Fans Not Kicking In, Help Appreciated!
Hello guys, recently purchased a Audi S3 whiskey plate and not so long after having this vehicle experienced my first problem of overheating, turned out the plastic propeller on the water pump was broke, so had that replaced, so now thinking the vehicle is fine went about my normal business only to experience another episode of the same problem, so this time 12volts were put to the fans to see if they worked and they did, so next the fuses were checked, a new temperature sensor was fitted as well, happens to be my thermostat was knackered, so again that was replaced and also a new fan control module was fitted, this still has not rectified the problem of the fans not kicking in, so all in all, I have had a new water pump, temperature sensor, thermostat and a new fan control module unit, I would very much appreciate some expertise from you guys here as this is frustrating one a considerable amount and again thank you!
corrado33
May 27, 2015 09:30 AM
MeganFrai
Sep 22, 2013 09:14 PM
frenchchef
Jul 9, 2013 06:41 PM
dpak
Jun 14, 2009 04:28 PM
jeffwantsaaudi
Dec 15, 2008 11:48 AM
