Audi shuts off when put in drive. Please help
Old Dec 5, 2006 | 01:14 AM
idice's Avatar
Default Audi shuts off when put in drive. Please help
This problem just started about 2 days ago. If i turn my car on it will run at 900Rpm but if i put it in drive or reverse it will shut off. Sometimes it will go at 100rpm when stoping at a light. Any ideas what that can be.
Old Dec 5, 2006 | 01:32 PM
rayveedub's Avatar
Default RE: Audi shuts off when put in drive. Please help
what kind of car?
Old Dec 5, 2006 | 03:47 PM
GeilKyle2's Avatar
everything you come to a stop, or everytime you put the car in gear you have your foot on the brake, sounds possibly like a rip in the brake vacuum booster. Unless you have an old audi with hydrolic assist from the power steering and then we can rule a vacuum assist out. I guess it really depends on the car
Old Dec 5, 2006 | 05:04 PM
idice's Avatar
Sorry. I have an 2000 A4. The car only drops in RPM and or shuts off when you stop at a light coming with like 35mph. If you let it drop in gears 3 - 2 -1 then it docent always do it. How do i check the transmission fluid i don't have a dip stick?
Old Dec 6, 2006 | 12:54 AM
dankhound's Avatar
Try cleaning your throttle body and checking for vacuum leaks. The trans fluid check is rather difficult. You need a scan tool to read trans temperature and then you remove a plug in the bottom of the trans to see where the levels at.
Old Dec 6, 2006 | 03:41 PM
GeilKyle2's Avatar
Also could be an issue with the t.c.c. (torque converter clutch). If it's not releasing, or if it's dragging that would cause her to shut off anytime it's put in gear or when coming to a stop.
skidoo800
Nov 10, 2012 11:08 AM
Abs27
Dec 23, 2010 05:40 PM
f_gold
Jul 11, 2010 09:49 PM
f_gold
Jul 11, 2010 08:31 PM
ficek801
Jan 12, 2008 12:21 AM
