Automatic transmission won't engage in R or 5th
Old 12-12-2006, 12:05 AM
justnsane's Avatar
Default Automatic transmission won't engage in R or 5th
I have a 97 A4 1.8t automatic Quattro. It suddenly wouldn't shift into reverse, and while driving forward won't go all the way into 5th gear. The shift indicator lights on the dash have all lit up as well, can't tell which position the shift lever is in. Any help would be greatly appreciated.
Old 12-12-2006, 11:25 AM
icrasheda90's Avatar
Default RE: Automatic transmission won't engage in R or 5th
i have this same issue
Old 12-15-2006, 01:12 PM
dankhound's Avatar
Scan the tcm for faults. It sounds like your in emergency running mode.
Old 12-19-2006, 07:21 PM
justnsane's Avatar
Isthere more than one place to hook up a tcm to? The one in the rear seat ashtray is missing or wasn't there to begin with.
Old 12-20-2006, 11:25 PM
dankhound's Avatar
Check the drivers sideunder the dash. There is only one place to hook the scan tool up to.
Old 01-13-2007, 05:26 PM
justnsane's Avatar
DTC (codes)
P1425, P1427
Manufacturer Contrl
Aux Emission Controls
P0102
MAF or VAF
A
Circuit Low Input
P1196, P1198
Manuf. Contrl
Fuel Air Metering
P0134, P0140
O2 Sensor
CKT No Activity
(Bank 1 Sensor 1 & 2 respectivley)
DTC Pending (Codes)
No Faults Detected.
Old 01-13-2007, 05:35 PM
P1425 is the most important that the EVAP system ( shorted wire to ground ) on the canister purge valve this would set all the other codes
Old 01-13-2007, 05:46 PM
but having said that its nothing to do with the tranny problem this is a separate issue
Old 01-14-2007, 02:26 AM
tractioncontrol's Avatar
Wouldn't the o2 sensors having no signal cause the rest of the issues putting the car into safe mode and not allow it to shift into fifth gear to insure no damage is done to the tranny? I know this is how it works on ford mustangs.
Old 08-04-2007, 09:20 PM
justnsane's Avatar
Changed the o2 sensors, and finally hooked it up to a computer and cleared the codes. Everything seems to be working fine, tranny shifts normally, and no mil lit up.
alvocado
07-12-2021 11:49 AM
MyDreamCar
08-02-2009 06:43 PM
Phat_J
B7 Models
04-21-2009 03:19 PM
kayone
01-12-2008 10:16 PM
02DolphinA4
01-04-2007 12:35 AM
Quick Reply: Automatic transmission won't engage in R or 5th
