B6 4.2 S4 40V Engine Trouble
Old Dec 23, 2012 | 04:05 PM
DEROCK's Avatar
Default B6 4.2 S4 40V Engine Trouble
Hello
I picked up and S4 recently with motor problem knowing it had a problem.
The motor idles real rough, backfires, low power, smokes, and dies. When it dies it does not restart for a while, but randomly it will start.
Did a Vagcom scan and this is what I got:
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
VIN: WAUPL68E54A284473 Mileage: 260620km/161941miles
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8E0 910 560 C HW: 8E0 907 560
Component: 4.2L V8/5V G 0010
Coding: 0007771
Shop #: WSC 08166 444 52519
VCID: 254FF043EFADDD30723
15 Faults Found:
17799 - Camshaft Position Sensor Bank 2 (G163)
P1391 - 002 - Short to Ground - MIL ON
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - MIL ON
16689 - Cylinder 5
P0305 - 001 - Misfire Detected - MIL ON
16690 - Cylinder 6
P0306 - 001 - Misfire Detected - MIL ON
16691 - Cylinder 7
P0307 - 001 - Misfire Detected - MIL ON
17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28)
P1347 - 002 - Incor. Correl. - MIL ON
16692 - Cylinder 8
P0308 - 001 - Misfire Detected - MIL ON
17537 - Fuel Trim; Bank 2 (Mult)
P1129 - 002 - System too Rich - MIL ON
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 001 - System too Lean - MIL ON
16688 - Cylinder 4
P0304 - 002 - Misfire Detected - MIL ON
16717 - Knock Sensor 2 (G66)
P0333 - 001 - Signal too High - Intermittent
18308 - Coolant Fan Control 2
P1900 - 004 - Open or Short to Ground - Intermittent
16705 - Engine Speed Sensor (G28)
P0321 - 008 - Implausible Signal - Intermittent
16687 - Cylinder 3
P0303 - 002 - Misfire Detected - MIL ON
18080 - Coolant Fan Control 1
P1672 - 004 - Open or Short to Ground - Intermittent
Readiness: 0000 0001
Did a compression test with a cold engine and these are the results:
Bank 1(passenger side)
4) 120 psi
3) 115 psi
2) 120 psi
1) 110 psi
Bank 2(driver side)
8) 0 psi
7) 0 psi
6) 30 psi
5) 0 psi
Did a leak down test on bank 2 with a cold engine and these are the results:
between 20-40%
However when rotating the crankshaft clockwise by hand i noticed that at times the left camshaft on the drivers side bank would not spin sometimes and I had a lot of trouble seating the valves. I would hear an occasional pop and the camshaft would spin a half a turn abruptly. I observed the the passenger side camshafts did not behave in the same way, they always turned with the crankshaft.
Is this a camshaft adjuster problem or is this normal? Am I jumping the gun here or is there anything else to look for?
Thanks
Daryll
Old Jan 1, 2013 | 12:00 PM
ImTheDevil's Avatar
Sounds like a failed cam chain tensioner to me. That'll throw the cam phasing out, kill your compression, and create the misfires. If your car's build date is earlier than 10/04, they were known for this. The fix is brutal - $500 for the CCT, additional cost for anything else, and at least a partial engine pull to replace the parts.
A4.power
Oct 29, 2013 06:25 PM
franknbeans
Oct 27, 2009 01:14 AM
mirov0
Jan 2, 2009 02:07 PM
Johnnyd3689282
Sep 28, 2006 02:54 AM
badass38
Jul 1, 2006 11:17 PM
