Before you replace your coilpacks
Old Apr 28, 2009 | 10:42 PM
munkydotorg's Avatar
Default Before you replace your coilpacks
Just a quick tidbit I learned today. I had been having misfire issues, with random misfires, and misfires on cylinder #4 on my 99.5 A4 Quattro 1.8T. So in standard troubleshooting fare, I swapped the packs on #3 and #4 to see if the misfire moved with the pack.
I also checked over the connectors of my other coilpacks to ensure everything was tight, when I noticed the ground screw was a little bit loose. 1 10mm wrench and about a full turn later, everything was nice and snug, put the cover back on, then started her up, let her run a bit, then drove it around to see if I was still having issues.
None. Problem fixed.
So word of advice, when you are having misfire issues, make sure to include checking that ground wire first. May save you some time, headaches, and money.
Now, I didn't think to take a picture, but I found an ECS coil pack hold down one to show
hope this helps someone.
Old Apr 29, 2009 | 04:08 AM
Midniteoyl's Avatar
Good tip. Grounds cause more problems than most realize.
Old Apr 29, 2009 | 08:23 PM
it's amazing the headaches you can have from one loose connection
Old Apr 29, 2009 | 08:28 PM
Darkprodo's Avatar
Well.... even better tip. Audi coils that bolt down.... like older 1.8t and 2.7t more than rarely go bad. Not nearly as much as the other kind.
but yea, grounds cause alot of issues and can have you chasing wires forever
Vannylasky
Nov 26, 2012 05:46 AM
Vannylasky
Mar 3, 2011 06:46 PM
getinlost
Sep 6, 2010 09:39 PM
wolfdog
Dec 10, 2007 05:11 PM
neur0tic
Jul 31, 2007 01:27 AM
