blower motor control
Old Oct 2, 2007 | 01:45 PM
jello's Avatar
Default blower motor control
Hi all, I Recently purchased 2000A6 2.7t 6spd. besides the dash looking like a Christmas tree the blower motor for the heat is triping the fuse.I Did a little under the dash and can jump the controls to make blower turn on and off but can't seem to get control head to function properly .Also looks like someone may have been in the wires before me.Any ideas on how to diagnose this problem is it common?........thanks
Old Oct 13, 2007 | 04:05 PM
WolfeA4's Avatar
Default RE: blower motor control
This may not be the answer but I would try and replace the blower motor resister, if thatyear hasthat part.
Old Oct 15, 2007 | 02:37 PM
jello's Avatar
Well I got the blower to work by removing the leed from the variable fan speed control but I can only get it to blow on hight all the other heater control function properly except to fan speed if I hook up the wire the fuse blows.Do you know if there is a way to repair that part of the control head or does it just have to be replaced completly?
Old Oct 15, 2007 | 02:49 PM
techbod's Avatar
yep its the resistor and you only get 1 speed.
Heater components in vehicle interior[/align]Removing and installing series resistor -N24 for fresh air blower[/align]
‒Remove glove compartment. [/ul]
‒→ Unplug connector.
‒Remove bolt -A-
‒Remove series resistor -B- in direction of arrow. [/ul]
[IMG]local://upfiles/12092/B12F5A07EF9D484CB4E4AF93C9D0790A.jpg[/IMG]
Old Oct 15, 2007 | 10:34 PM
jello's Avatar
Hey thanks for the info and the diagram dave. This will make my ride a lot more comfortable in this crappy NY weather!Do you know of a good place to get a replacement resistor pack ?I'm assuming the deal will want my first born for a OEM part.
Saxrasta
May 11, 2014 11:27 PM
kortneylee
Mar 21, 2010 07:53 PM
johnnythefox
Jan 26, 2010 08:27 PM
magicfan
Feb 5, 2008 01:10 PM
Lilo Shark
Jan 19, 2007 06:35 AM
