Brake fluid change using Mity-Vac
Old Oct 16, 2006 | 01:26 PM
dmklever's Avatar
Default Brake fluid change using Mity-Vac
I tried to change the brake fluid on my 97 1.8T yesterday using a Mity-Vac. It didn't work; it didn't seem to be able to pull out fluid in any quantity. Also seemed to draw a lot of air out, apparently in though the threads of the bleed fitting.
Has anyone else had any experience using a Mity-Vac to change the brake fluid on these things? I have used the Mity-Vac on my motorcycles; it works great there. But this one has me scratching my head. Thanks
Dave
Old Oct 16, 2006 | 03:29 PM
Coop's Avatar
Default RE: Brake fluid change using Mity-Vac
go to the store and buy a cheap turkey baster and some vacuum hose. use that to suck out the fluid once you pull the screen out. this is what they do at the dealer when they tell you your brake fluid needs to be changed.
Old Oct 16, 2006 | 10:01 PM
AWDaholic's Avatar
Senior Administrator
vacuum hose, I just swing by the fish store and get a hunkka hose, and toss the whole kit in somebodies dumpster until next I need to flush a system...
robesimi
Mar 11, 2015 07:35 PM
jaymac
Feb 1, 2010 06:24 PM
luzarj
Oct 18, 2009 09:57 PM
virtualelvis
Jul 21, 2009 04:06 PM
Pencilcase
Apr 15, 2008 07:32 PM
