Brake Fluid Leak
Old Feb 20, 2008 | 11:53 AM
moosefist's Avatar
Default Brake Fluid Leak
I have been having a problem with brake fluid leaking from my driver side rear wheel. I initially thought it was coming from the fluid lines which lead me to putting stainless steel lines on the car. The leak persisted and i recently noticed it only leaks when i am using my e-brake to park. I believe it is coming from where the e-brake cable goes into the wheel?? Basically i am wondering if the whole caliper is bad or if there is just a seal that needs replacing. Thanks any help or suggestions are appreciated
Old Feb 20, 2008 | 01:58 PM
nemohm's Avatar
Default RE: Brake Fluid Leak
Replace the faulty rear caliper (common problem) with new or rebuilt one. (I’d make sure to locate the leak first-wash and clean the wheel/caliper area).
Old Feb 20, 2008 | 02:43 PM
moosefist's Avatar
Is it difficult to rebuild a caliper yourself. i am usaully pretty good at this kind of stuff but does it require a lot of specialty tools. And if it is better for me to bring it to a shop for this what kind of bill should i expect for them rebuilding a caliper?
Old Feb 20, 2008 | 02:55 PM
techbod's Avatar
you can buy a repair/rebuild kit and all it isO rings so if you can get the size then its a simple replacement ( calipers never really fail its the seals that were out )
Old Feb 21, 2008 | 10:23 AM
moosefist's Avatar
http://cgi.ebay.com/ebaymotors/BMW-9...spagenameZWDVW
Would these work for an audi. I kind of am having a problem finding a kit that i can buy with PAypal. MY debit card is MIA and my damn bank it takes nearly a month to get a replacement. I also thought thee may work since i think the audi uses firling brakes stock???
http://cgi.ebay.com/ebaymotors/Girli...em200201313142
elduderino200
Oct 8, 2013 09:39 PM
CyphrMedic
Sep 5, 2010 12:55 PM
akirk
Dec 9, 2008 05:57 PM
jakej
Nov 12, 2008 08:55 PM
selfemployed03
Feb 24, 2007 04:07 AM
