c5 2.5tdi AKE annoying pump fault
Old Apr 9, 2017 | 10:58 PM
yury's Avatar
Default c5 2.5tdi AKE annoying pump fault
2001 Audi A6 C5 2.5TDI AKE quattro 6sp 27,000km NO CODES
inector pump died 00550 and more, but it started nicely and then jumped revs. was undrivable.
changed it to another (drove that car so it was fine) but the engine was BAU or AFB dont recall.
had problems with that, the electronic unit ontop the pump was not working well with my car so i swapped that part of the pump with my old one from the broken pump.
bled it and it started fine, checked with vcds and tdi graph was fine.
no fault codes.
no vcds used to bond anything, just exchanged the housing of pump.
then i noticed when the car is below its working temperature (<85-90celsius)
well when engine is coldstarted it would run rough and revs jump for a millisecond each 5th second, like a kick or like its pouring gunpowder(well)
into the engine each 5th second så it just jumps.
at idle at half load at no load
while driving, it judders when low load or no load
at sertain circumstances when factors like which gear, how much throttle and
how the road is uphill or downhill,
its always jumping rev each 5second, but when it judders it just judders until
throttle position or load is changed
but at full load its no problems.
and that dissapears as soon it gets warm , about 85celsius.
if cold and i check tdi graph then the jumps dissapears while checking.
if warm and running good but full heat on and stand at idle so the engine temp goes to 60celsius (cold) it still runs very good until restart (like just turn off turn on in a sec) and it starts misfiring and jumping
if started hot, no problems, ONLY after cold start.
starts always easy. glowig light works good.
been driving like this for 6 months now its making me insane each morning.
i have vcds full and can read blocks.
sorry for bad english, long time no write, can read and understand perfectly.
taking all tips, tricks, wonders, questions, answers very happily
i can video shoot the behavior cold/hot and put on youtube if wanted.
Old Apr 10, 2017 | 05:00 AM
Jing Gao's Avatar
I also have the same issues with you.
amiram
May 3, 2015 02:32 PM
Steven_c
Feb 25, 2015 10:31 PM
veghard
Jul 23, 2014 01:43 PM
richieski
B7 Models
Apr 20, 2013 01:02 PM
Franky0707
Feb 18, 2012 12:24 PM
