Car is dead...
Old Aug 20, 2008 | 08:29 PM
RobertMac's Avatar
Default Car is dead...
I have a leak in my car cause the tropical storm that hit fl...my driver side and behind the driver side was soaked...now my electronics dont work...what could it be???
Old Aug 20, 2008 | 11:27 PM
auditech79's Avatar
Is there stains on the headliner and or pillars? If there is its a leak that comes from sunroof drains. There are four total, you need to remove the headliner (or pull it down enough to get at the drains) and pop off the drain from the sunroof track. There is a little rubber white connetor peice at the end of the hose that needs to be re-sealed. What you do is use a screwdriver and pry the white connector peice off the drain hose, once its off coat the inside of the connector with clear silicone and put it back on the hose. Let it dry over night then re-install it the next day. It should be fixed.
Old Aug 20, 2008 | 11:28 PM
auditech79's Avatar
Oh and as for the electronics, water probably got into the comfort control module under the carpet on the driver's side, so you would need a new module.
Old Aug 21, 2008 | 04:39 AM
RobertMac's Avatar
I cant seem to find the ccm...i know its under the driver seat...but i cant find it...i feel some thing like a flat board...feel like plastic but its hard to remove...it would prob be that but i cant pull it out man...unless it is clipped but its hard to see considering i am just moving my hard around under the flood carpet.
Old Aug 21, 2008 | 06:34 AM
RobertMac's Avatar
Also where can i buy a used one i have an audi s4 2000
Old Aug 22, 2008 | 08:12 AM
CRAZYHAWK's Avatar
Old Aug 22, 2008 | 02:27 PM
auditech79's Avatar
Its in the trunk on a 2000 S4, you have to remove the trim on the right side.
Old Aug 24, 2008 | 04:07 AM
RobertMac's Avatar
update...it wasn't the ccm thankfully...no one seemed to know what cause the battery to completely died..i went to the store and just bought a new one...every thing was back to normal....and i fixed all the leaks....4 hours of labor for only 100 bucks of a local mechanic in miami.
thorjov
Nov 4, 2015 09:19 PM
sujoyron
Oct 4, 2014 01:56 PM
tom.beckman
Sep 2, 2013 10:19 AM
wdiaz300
May 14, 2008 08:10 PM
proulx00
Jul 5, 2007 11:11 AM
