Car is dead...
Is there stains on the headliner and or pillars? If there is its a leak that comes from sunroof drains. There are four total, you need to remove the headliner (or pull it down enough to get at the drains) and pop off the drain from the sunroof track. There is a little rubber white connetor peice at the end of the hose that needs to be re-sealed. What you do is use a screwdriver and pry the white connector peice off the drain hose, once its off coat the inside of the connector with clear silicone and put it back on the hose. Let it dry over night then re-install it the next day. It should be fixed.
I cant seem to find the ccm...i know its under the driver seat...but i cant find it...i feel some thing like a flat board...feel like plastic but its hard to remove...it would prob be that but i cant pull it out man...unless it is clipped but its hard to see considering i am just moving my hard around under the flood carpet.
update...it wasn't the ccm thankfully...no one seemed to know what cause the battery to completely died..i went to the store and just bought a new one...every thing was back to normal....and i fixed all the leaks....4 hours of labor for only 100 bucks of a local mechanic in miami.
