Car won't start!!!!
Old Feb 9, 2016 | 04:56 PM
Derek Quad's Avatar
Default Car won't start!!!!
So I was sliding around in the snow last night having a good ol time shut the car off n started it multiple times came home for the night. Went out this morning and went to start the car and nothing. All the nights come on starters not bad battery is new alternator was replaced yesterday. What the f$%# is going on!!??? PS I have a B5 98 a4 Quattro 1.8T. Thanks
Old Feb 10, 2016 | 07:56 AM
dave944's Avatar
Before you sling any more parts at it, double check the electrical connections at the starter. In particular the smaller solenoid wires.
Old Feb 10, 2016 | 10:12 AM
Derek Quad's Avatar
I checked both starter wires. It seems like something all of the sudden not giving it power? Is there a relay or som type of security system issue the b5 has?
Old Feb 10, 2016 | 02:55 PM
dave944's Avatar
I could be either one. When you unlock the car, do you use the button on the key fob or do you unlock it manually with the key in the door lock?
There will be power on the large starter wire at all times. If you're not getting voltage on that one, there is definitely a problem with that wire. Does the starter click at all when you turn the key? You should get power on the large wire at all time but the smaller wire will only have power supplied to it when the ignition key is turned all the way to that start position. I'd put a meter on both and check them first.
3dviz
Jul 6, 2014 03:05 PM
StefanEU
Dec 9, 2012 08:44 PM
Angrywasp
Apr 2, 2011 08:53 AM
ride1157
Jul 8, 2009 04:17 PM
t2002c
Aug 16, 2006 05:11 PM
