Cd Changer
Cd Changer
Own a 2003 audi a6 3.0 quattro, want to put in a cd changer in rear of car , are these Audis ,the ones sold without cd changers ,pre wired or does a wire job need to be done to radio, if not where is the 13 pin din connector located ,its somewhere in the jack compartment.
Please respond. Thanks.
RE: Cd Changer
I'm not an expert in A6's, but I believe it is prewired, and the DIN is located in the trunk, left side (as you're lookin at it) behind a secret panel (shhhhhh) between the wheelwell and the rear of the trunk... If I'm wrong someone WILL correct me!
RE: Cd Changer
Pre-wiring should be bundled with all the other wires above the rear driver's side wheelwell where you would find the jack. Take a flashlight and look for the thicker round black cable bundled with all the other wires using a plastic tie. Tied to the end of the cable is a gray foam protector for the connection head.
