CEL code P1423 and P1411 Secondary Air Flow
Old May 19, 2010 | 05:03 PM
tdawley's Avatar
Default CEL code P1423 and P1411 Secondary Air Flow
HELP.....
I have checked everything from hoses, to the pump, to relays and fuses....AND THEY ALL ARE FINE.
Am I missing something when checking the sytem? The pump activates and shortly after the engine light comes on. I think the EGR's are opening, but cannot be sure. I cleaned them with carb cleaner and it appears as if they are moving with vacuum. My vacuum hoses are fine and the pump blow good strong air. The solenoid activates when power is put to it.
WHAT AM I MISSING.....I am sooooo tired of this issue
The codes relate to the Secondary Air Flow Bank 1 and Bank 2 - air flow too low.
Old Aug 15, 2013 | 03:49 PM
Jetmonkey64's Avatar
Hi Tdawley,
I know that your post is over 3 years old but just in case you are still there; did you ever find out what the problem was? I got the same issue and followed the Bentley manual from power source to fuse to relay to grounding point to no avail. The only thing left that I can think of is to flash the ECM. I have a POS Audi 2004 A6 2.7T
Jetmonkey64
bosscunningham
Jan 28, 2014 11:30 PM
kbunting
Sep 5, 2010 04:19 PM
bdmstang
Dec 10, 2009 04:40 PM
mikehh
Jan 25, 2009 01:24 PM
bolob5
Jul 10, 2008 01:03 PM
