clutch installed, now it wont go into gear..
Old Mar 13, 2010 | 06:05 PM
ericp1.8T's Avatar
Default clutch installed, now it wont go into gear..
1.8t b5 A4.. Put in a new clutch and new trans, but now when I turn the car on I can't shift into any gear.
Ideas?
Old Mar 13, 2010 | 08:12 PM
ketteman32's Avatar
double check and make sure the shifter linkage is hooked up to the transmission
Old Mar 13, 2010 | 08:28 PM
ericp1.8T's Avatar
it is.. So far I pulled about 1 cup out of they lines bleeding it, no air...
Checked the slave cylinder and it seems to be working fine, still nothing...
extended the slave cylinder pushrod 10mm and still nothing...
My father thinks the pushrod isn't sitting right and just keeps slidding past the forks.
I don't know what to do and i'm starting to freak out
Old Mar 13, 2010 | 09:04 PM
ketteman32's Avatar
is it a rebuilt tranny or a new one? when installing the new tranny did you notice any damage to the throw out bearing, if the slave isnt sitting on the little indent on the plate that it rest inside the trnamission it wont shift. when trying to use the shifter what does it feel like and another thing to try is disonnect the shifter and manually shift the transmission if you can shift the transmssion manually then you kno the internals are most liklely good
ibe3pac
Aug 21, 2022 02:24 AM
slolatino
B7 Models
18
Feb 23, 2015 10:59 AM
nick17
Mar 5, 2009 03:25 PM
smootboy5
Nov 22, 2007 11:20 PM
smootboy5
Nov 22, 2007 11:28 AM
