Crazy Electrics
hi,
I recently fitted a new wiper linkage and motor to my audi a3 99 plate 1.8T. The wiper linkage came with used motor on it, all worked fine so i fitted, turned the car off and went in the house. Came back out later to head to my mates and it was working still and no issues in the car.
It wasnt till later that night when i went to drive home and the car wouldnt start. Starter motor is going for it, all my lights still work, radio ect but the instument cluster has no power going to it and electric windows wont function.
I got in and disconnected the wiper motor to see if it would make a firrence but still no luck.
Has anyone came across this issue before??
If the communication port is dead meaning it will not power up a scanner then check your fuses. It is usually the same one tied into the power outlet (cigarette lighter).
If it is a matter of no communication then there is somthing bring down the can communication line. Could be a module.
So i checked the battery today and its all good, fuse for the cigarette lighter is fine aswell. Could there be any relays causing issues? I can only think the wiper motor that came with the linkages is to blame
Do you check the battery??? May be the battery hasn't got enough power to start the engine.
________________________________
No matter how long the rain lasts, there will be a rainbow in the end. No matter how sad you may be, believe that happiness is waiting.
Autocom CDP for car active service
