dangerously dim headlights...replace bulb or unit
Old Jan 13, 2008 | 10:50 AM
advisor02's Avatar
Default dangerously dim headlights...replace bulb or unit
I have a '99 Avant which is becoming increasingly dangerous to drive at night due to the dim headlights. They still work (just not very well), as do the high beams which put out great light and was wondering if I can just replace the bulbs or if the entire unit needs to be replaced?
Any comments or feedback would be greatly appreciated!
Thanks,
Chris
Old Jan 13, 2008 | 10:59 AM
sepp's Avatar
Default RE: dangerously dim headlights...replace bulb or unit
Are the lenses still transparent, and haven't become sand blasted, or fogged up from the inside?
You can try to pull out the lamps, and check if the connection is looking like it's corroded, or dirty.
Old Jan 13, 2008 | 10:14 PM
WolfsA62.8Q's Avatar
If the high beams put out lots of light, your headlight assembly sounds Ok. Replace the bulbs, it it's still dim, then get the assemblies, they cost a lot more than justs the bulbs.
Old Apr 1, 2008 | 07:17 PM
zippy_gg's Avatar
Do you have halogens or HID low beams?
Either way you can just replace the bulbs, or get a new HID kit... Read on...!
HID bulbs (actually capsules) tend to become dim with the years, and your car is a 99 which would fit in the category of "old" HID capsule. The trouble is that not all HID "bulbs" have the same connectors, unless you want to buy the expensive stock units. You may be better off replacing the ballast/igniter and capsules as a kit. www.cqlight.ca is a known vendor and I have been very satisfied with the kits I bought for various BMW motorcycles. A car kit (2 ballasts/igniters + 2 HID bulbs, wiring, etc) runs about $150.00.
Old Apr 2, 2008 | 04:31 PM
PRican1.8T's Avatar
www.vvme.com has some kits cheap! i got one for my car cause i had the same exact problem and getting the HID kit worked VERY well. it was about $78 shipped with 6000K. plug and play install. the hardest part i found was finding a place for the ballast. they work GREAT. no problems with them so far and they were less than $100 shipped. you're better off doing that cause i changed my bulbs to really good bulbs and they STILL weren't bright enough. almost hit a bicyclist and a cat. just get the HIDs and forget about it.
vtraudt
Dec 4, 2010 10:32 PM
mb2audi
Nov 29, 2010 07:59 PM
mnets
Feb 17, 2008 12:05 PM
gillfish
Feb 26, 2007 04:27 PM
dudley doright
Oct 4, 2004 06:44 PM
