door panel removal
Old Jun 22, 2006 | 06:52 PM
auS4di's Avatar
Default door panel removal
anyone know how to remove the door panels on a 2000 b5 s4?? i need to replace the window lock switch. it is stuck in the locked position and the only way someone in the back can put down their window is if i hold the button in. thanks
Old Jun 25, 2006 | 01:51 PM
dankhound's Avatar
Default RE: door panel removal
Pull the trim piece that is near the top of the door. Start at the front and pop it out. There are 4 screws behind that. Remove the portion of trim near the handle. Theres two more screws under there. One more screw at the bottom of the door panel and it pulls off. Just replace any of the clips that break during removal. It will require some decent force to pull the door panel out of the clips.
tuned2.7A6
Aug 25, 2011 06:56 AM
stenicilyg
Jan 6, 2010 08:04 PM
kjones6039
Aug 25, 2008 01:04 AM
auS4di
Jun 22, 2006 09:16 PM
sharkbait
Sep 7, 2004 12:17 PM
