Engine Oil Bypass Filter
Old 12-21-2010, 12:32 AM
gcv's Avatar
gcv
gcv is offline
Default Engine Oil Bypass Filter
Hello, First post here.
I tried searching the forum without success, so sorry if this has been discussed before:
Has anyone installed an engine oil bypass filter in an AUDI or VW? Specifically the B5 A4 1.8T, which has known oil sludge issues.
I have just done so and will report back after a few thousand km.
The link with the product I used (no affiliation) is:
http://www.frantzoil.com/home.html
Basically I am taking part of the oil which exits the regular car's oil filter and running it through this (additional) ultra fine filter. The return (clean) oil is then taken up by hose to the engine oil cap.
These are often used in diesel engines, SUV's and trucks.
Comments are welcome.
Regards
gcv
1999, Audi A4, B5, 1.8T Avante, Auto
Old 12-30-2010, 03:22 PM
gcv's Avatar
gcv
gcv is offline
Default Update 1
It has been roughly 1000km on the first toilet roll filter element and I decided to change it. Frantz recommends the first filter be changed at 500 miles and then every 15,000km (sorry for the changing of distance units).
It is hard to confirm at this stage due to some excessive oil top ups (read below) but it looks like the oil is not getting as dark as it used to.
The most noticeable change is that when I lift the oil cap, there is no more sludge clinging to the underside. It is is just clean oil on it.
The oil filter element I replaced was virtually black!
I have had a few oil leaks due to errors I made tightening hoses but it all seams to be sorted out now.
With the next scheduled oil change in a few thousand km's, I will also change the Frantz oil filter element (toilet roll) again so the cycle starts with new oil and new filters. Then I will be make further note on the colour changes.
Until next time.....
gcv
rpaddock
09-17-2014 03:47 AM
zheka
B7 Models
04-15-2013 03:46 PM
bigsnowdog
12-28-2010 08:26 PM
justfixitup
08-15-2009 08:31 PM
wirepaladin
11-28-2007 01:55 PM
Quick Reply: Engine Oil Bypass Filter
