Engine swap
Old Jul 6, 2016 | 05:48 AM
Festus's Avatar
Default Engine swap
Can I/ is it worth the effort to swap a 2.8 with a 3.0?
Old Jul 6, 2016 | 07:24 AM
dave944's Avatar
Gonna be the same amount of work either way.. As long as you have the ECU for that 3.0, it could be certainly be done if the particular model had the 3.0 available as an option.
Old Jul 6, 2016 | 04:33 PM
Festus's Avatar
As far as I can find the 01 was not available with the 3.0. so your saying it would be a no go?
Old Jul 6, 2016 | 05:20 PM
dave944's Avatar
Not saying it can't be done but it may not be a smooth an upgrade as it may seem. Gone are the days when you can drop engines from different year models into a car and it not end up mating like it should. They do this crap on purpose it seems.. LOL
Old Jul 6, 2016 | 09:29 PM
Festus's Avatar
Does it need to be the exact ecu from the motor or would a replacement ecu for the same type of motor work? Also what about things like motor mounts and exhaust would they line up?
Old Jul 7, 2016 | 07:24 AM
dave944's Avatar
If you can get the ECU for THAT engine, it'd make things a lot easier in that department. Not sure about the engine mounts, exhausts, and most importantly, the bellhousing for mating the trans.....
curtmon03
Mar 19, 2012 08:35 PM
o0hmikee
Oct 24, 2011 10:19 PM
curtmon03
Oct 4, 2011 07:49 PM
impaler2383
May 17, 2006 11:29 PM
tbailey4
Mar 28, 2004 11:37 PM
